firewall setup missing KH 20.1 Build 1928
Zoltan
Post by Zoltan »
just a fresh install of KeyHelp and firewall setup is missing from the left panel, see screenshot:
http://prntscr.com/sphc1d
20.1 (Build 1928)
What did I wrong?
thank you
Zoltan
Re: firewall setup missing KH 20.1 Build 1928
You did nothing wrong.
If you are using Debian 10, than it is normal behavior, due to this feature is not yet present on a KeyHelp-Debian 10 system.
Zoltan
Post by Zoltan »
thank you!
than how to manage firewall settings?
Anyway what is the most recommended OS for KeyHelp?
nikko
Post by nikko »
I personally use Ubuntu because of the LTS. The firewall settings also work there.
prune
Post by prune »
I am also using it with Debian 9 currently and Im getting a reminder from Keyhelp to upgrade. So when I upgrade to Debian 10, no firewall? You mean just the firewall UI or firewall UI and firewall itself wont be working?
No UI.
The firewall is working.
Configurations must be done via cli.
superrandom
Post by superrandom »
Tobi wrote: Sun 31. May 2020, 07:55 No UI.
Shouldn't there be a default config? That isn't applied either, it's a wide open system upon installation of KH.
# iptables -nvL
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
 pkts bytes target     prot opt in     out     source               destination
 322K   37M f2b-sshd   tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            multiport dports 22
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
Chain f2b-sshd (1 references)
 316K   37M RETURN     all  --  *      *       0.0.0.0/0            0.0.0.0/0
root@miami:~# lsb_release -a
No LSB modules are available.
Distributor ID:	Debian
Description:	Debian GNU/Linux 10 (buster)
Release:	10
Codename:	buster
Maybe posting on the main site that it's Debian 10 compatible should be reconsidered? A debian 10 system is really wide open. Not sure where it goes wrong but the rules are there in /home/keyhelp/www/keyhelp/install/templates/iptables. I'd say that's worrisome given the regular control panel user (generally not so versed in fw setup).
