User login filter from IPs
The user does not have that choice, I think it make KeyHelp more secure.
Tony.
Re: User login filter from IPs
For now, you could add the following, to a .htaccess file in the KeyHelp web directory:
/home/keyhelp/www/.htaccess
# RESTRICT ACCESS TO DIRECTORY BY IP ADDRESS
# Include in .htaccess of any directory
<RequireAny>
Require all denied
Require ip 1.2.3.4
Require ip 5.6.7.8/12
# If local server access to the directory is required
# add the following; include the server ip addresses (ipv4 & ipv6)
Require local
Require ip 9.10.11.12
Require ip 2001:0db8:85a3:0000:0000:8a2e:0370:7334
</RequireAny>Re: User login filter from IPs
When i look in /home/keyhelp/www/ there is no ".htaccess" file, so I will have to create one?
Yes.
