Creating a Branded/Private Nameservers  [SOLVED]
Faruqa97
Post by Faruqa97 »
I am almost done with the migration from vestacp to keyhelp, the only issue I have is a way to create a branded nameserver.
The way it works in vestacp is changing simply changing template to child-ns, and then setting ns1.domain.com and ns2.domain.com as nameservers.
Where can I find a similar process in keyhelp?
Re: Creating a Branded/Private Nameservers  [SOLVED]
You may want to have a look here: viewtopic.php?f=11&t=9702
Faruqa97
Post by Faruqa97 »
Thanks, I just tested this on my test domain, and I can confirm that this is the solution. So easy than Vesta :D , this panel is so flexible, one thing missing is Nginx, but I have already configured that manually. :P
