File manager - no EDIT button  [SOLVED]
chaiavi
Post by chaiavi »
When using the filemanager i have a menu to do tasks on files but I can't find the "EDIT" task ?
I know that in a previous installation, I had this option to edit files in the file manager, how can I get it there?
I am attaching a screenshot to clarify
no edit function !?
no edit function !?
Re: File manager - no EDIT button
Hello!
Which KeyHelp version are you using?
It does not look like the current KeyHelp 20.1.
If you are running KeyHelp 20.1, can you please check the mime type of this file so I can investigate the problem further. Thank you.
file --mime-type <PATH TO FILE>
chaiavi
Re: File manager - no EDIT button  [SOLVED]
Post by chaiavi »
Thanks Alexander,
I am not sure what I did, but now it works as it should ...
I cannot reproduce the bug/feature
