Fehler bei der Intallation > Firewall
olpo
Post by olpo »
Bei der Installation tarten im Bereich Firewall Fehler auf.
Hier ein Auszug aus dem install.log
 exec  | mkdir -p -m 0755 /etc/nftables/
  files | nftables/nftables.conf => /etc/nftables.conf
  files | nftables/fail2ban.conf => /etc/nftables/fail2ban.conf
  exec  | nft -f /etc/nftables/fail2ban.conf
          /etc/nftables/fail2ban.conf:4:1-2: Error: Could not process rule: Operation not supported
          table ip fail2ban {
          /etc/nftables/fail2ban.conf:5:11-15: Error: Could not process rule: Operation not supported
              chain input {
Was ist nun zu tun?
Vielen Dank im Voraus!
Re: Fehler bei der Intallation > Firewall
welche Distribution kommt hier zum Einsatz?
olpo
Post by olpo »
Debian 10.4
Beste Grüße
Ole
delvita
Post by delvita »
Hm,
Bei mir gab es auch dort einen Error.
Das OS ist Ubuntu 18.04 (64-bit).
Kann man das korrigieren oder Nachinstallieren?
Gruss, Mike
ErrorLog
  files | firewall/rules/rules_ipv4_common => /etc/keyhelp/iptables/startup_rules_ipv4
  files | firewall/rules/rules_ipv6_common => /etc/keyhelp/iptables/startup_rules_ipv6
  files | firewall/keyhelp_load_rules => /etc/network/if-pre-up.d/keyhelp_load_rules
          Could not save file "/etc/network/if-pre-up.d/keyhelp_load_rules"
  [SKIPPED DUE PREVIOUS ERRORS] files | firewall/keyhelp-load-firewall-on-startup.service => /etc/systemd/system/keyhelp-load-firewall-on-startup.service
  [SKIPPED DUE PREVIOUS ERRORS] files | nftables/nftables.conf => /etc/nftables.conf
  [SKIPPED DUE PREVIOUS ERRORS] files | nftables/fail2ban.conf => /etc/nftables/fail2ban.conf
  [SKIPPED DUE PREVIOUS ERRORS] exec  | chmod 0755 /etc/network/if-pre-up.d/keyhelp_load_rules
  [SKIPPED DUE PREVIOUS ERRORS] exec  | chown keyhelp:keyhelp /etc/keyhelp/iptables/*
  [SKIPPED DUE PREVIOUS ERRORS] exec  | systemctl enable keyhelp-load-firewall-on-startup.service
  [SKIPPED DUE PREVIOUS ERRORS] exec  | nft -f /etc/nftables/fail2ban.conf
  [SKIPPED DUE PREVIOUS ERRORS] import | /home/keyhelp/www/keyhelp/install/templates/firewall/rules/default_common.sql => keyhelp
  [SKIPPED DUE PREVIOUS ERRORS] import | /home/keyhelp/www/keyhelp/install/templates/firewall/rules/active_common.sql => keyhelp
Hier die Lösung deines Problems
viewtopic.php?p=26489#p26489
