Updating server in non live environment  [SOLVED]
lmarcos
Post by lmarcos »
Hi again,
I am upgrading my main server and need to install some software with web access (phpBB). So what I'm basically doing is starting a server and doing all the stuff there in parallel with the production server. And then, I will backup the production server database, restore it in the new server and point the domain to the new server once I make sure everything is working as expected.
Is there a way to access the user folder through a web browser? Right now the domain is being used by the production server, but I already created the domain for the user in keyhelp.
Thanks in advance.
Re: Updating server in non live environment  [SOLVED]
Do you use Windows?
You can edit the "hosts" file.
There you can point your domain to the new server.
These changes are only affecting your computer.
All other users will still us the production server.
Have a look at:
https://support.rackspace.com/how-to/mo ... osts-file/
lmarcos
Post by lmarcos »
Found it, thank you :D
