Known Issue 20.2 | FTP Failed to start / ECONNREFUSED  [SOLVED]
Problem: FTP connection not possible. Proftpd cannot be started properly.
Cause: The configuration in the init script "/etc/init.d/proftpd" was incorrect.
Affected systems: Affected are all systems with Ubuntu 20.04
Fixing the problem:
Simply execute the following command: ATTENTION - ONLY FOR UBUNTU 20.04
wget https://install.keyhelp.de/misc/proftpd -O /etc/init.d/proftpd ; chmod +x /etc/init.d/proftpd ; systemctl daemon-reload ; service proftpd restart
Otherwise the fix is part of the upcoming update.
Blackmoon
Re: Known Issue 20.2 | FTP Failed to start / ECONNREFUSED
Post by Blackmoon »
Danke für den Hinweis. Hat funktioniert.
Solche Themen vllt. pinnen, damit Sie gleich oben ersichtlich sind.
