Visual display in the control panel  [SOLVED]
smied
Post by smied »
Tabs won't open
only url changes
does not work here:
Add domain
https://cp.sitesample.web/index.php?page=domains&action=add#tab-general-settings
https://cp.sitesample.web/index.php?page=domains&action=add#tab-interpreter
works here:
User administration
https://cp.sitesample.web/index.php?page=admin_accounts_admin&sid=sampleid
https://cp.sitesample.web/index.php?page=admin_accounts_user&sid=sampleid
For example, nested tabs won't open
Safety
Other...
Those tabs that are initially expanded work fine
p.s.
Everything works on a fresh installation of the control panel
Re: Visual display in the control panel  [SOLVED]
So I am assuming, you have either made some changes in white-label, installed an other theme, modified an existing theme, had a browser extension installed which interferes with the tabs and so on.
