can't download keyhelp
i'm using ubuntu for my website but however when i try to download keyhelp it starts downloading but at the end it stops and says "failed: network is unreachable"
thanks for help!
Re: can't download keyhelp
How did you try to download the software?
well basically i typed in putty this: wget https://install.keyhelp.de/get_keyhelp.php -O install_keyhelp.sh ; bash install_keyhelp.sh ;
also i'm using sftp
wget -4 https://install.keyhelp.de/get_keyhelp.php -O install_keyhelp.sh ; bash install_keyhelp.sh ;Data Collector für Community Support
nah, it said connection timed out retryingJolinar wrote: ↑Sun 20. Sep 2020, 20:21 Please test this command:Code: Select all
it spams connection timed out retryingcalamity wrote: ↑Sun 20. Sep 2020, 20:28nah, it said connection timed out retryingJolinar wrote: ↑Sun 20. Sep 2020, 20:21 Please test this command:Code: Select all
so is there another fix or?Jolinar wrote: ↑Sun 20. Sep 2020, 20:21 Please test this command:Code: Select all
Domain resolving works well on your server?
Outgoing connections are not limited (firewall)?
Maybe the debug flag of wget (-d) will output additional information, or the output of other tools like traceroute etc.
