Cron: test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
gustavohellwig
Post by gustavohellwig »
/etc/cron.daily/check_updates:
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
- Looks like that the solution is just to replace the script:
to: apt-get update
E.g: I saw this in the internet: If I run this, I have the same error:
sudo apt update | grep packages | cut -d '.' -f 1
But if I run this, I doesn't:
sudo apt-get update | grep packages | cut -d '.' -f 1
gustavohellwig
Re: Cron: test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
Hey guys, some ideas on how to solve this?
I'm receiving an email every day about that.
So replacing the content of the script with the line which does not result in the Warning message should fix it.
Anyway, this script seams not to be part of minimal OS installation and does not belong to KeyHelp either. Therefore the problem you describe here is not really related to KeyHelp.
gustavohellwig
OK.
The problem is fixed with the replacement of the content from the file: /etc/cron.daily/check_updates adding apt-get instead of just apt.
I did the test even yesterday before your reply and the email was not sent today.
So, how to reply to that bug be fixed?
Like I said, this file 'check_updates' is not part of KeyHelp or of a minimal operating system installation. You should point your request for fixing to the maintainer of the application, or to the people who installed this file on your server.
This has nothing do with KeyHelp nor is it a bug of KeyHelp.
