fresh installation on ubuntu 20.4 php error
dioporken
Post by dioporken »
On a fresh installation of keyhelp on a fresh ubuntu 20.4 VPS installation I get PHP-FPM [ERROR]
I attach my install.log
Installation is running:
Update sources list ... [OKAY]
Installation requirements ... [OKAY]
Hostname ... [OKAY]
Sudo ... [OKAY]
Bind9 ... [OKAY]
SSL/TLS ... [OKAY]
PHP ... [OKAY]
Apache web server ... [OKAY]
PHP-FPM ... [ERROR]
MariaDB ... [OKAY]
KeyHelp ... [OKAY]
Firewall ... [OKAY]
SSH ... [OKAY]
ProFTPD ... [OKAY]
Postfix ... [OKAY]
Dovecot ... [OKAY]
OpenDKIM ... [OKAY]
Email protection ... [OKAY]
AWStats ... [OKAY]
Fail2ban ... [OKAY]
Logrotate ... [OKAY]
PhpMyAdmin 4.9.7 ... [OKAY]
Adminer 4.7.7 ... [OKAY]
Roundcube 1.4.9 Multilanguage ... [OKAY]
Rainloop 1.14.0 (Community Edition) ... [OKAY]
Quota ... [OKAY]
Apparmor ... [OKAY]
7-zip ... [OKAY]
Hide LTS notice ... [OKAY]
Update message of the day ... [OKAY]
Nano ... [OKAY]
Curl ... [OKAY]
Cron daemon ... [OKAY]
Errors occurred during installation!
For more information, see the log file:
/var/log/keyhelp/install.log
If you need help, please visit our multilingual support community:
https://community.keyhelp.de
You will find your login information on your server in the file:
/root/keyhelp_login_data_2021-01-14_21-30-53
!!! Attention !!!
The system will reboot in a few seconds (Cancel with CRTL+C).: 0
install.log
PHP-FPM [ERROR]
(251.56 KiB) Downloaded 556 times
Re: fresh installation on ubuntu 20.4 php error
Have a look in your install.log, section „ PHP-FPM“.
Try to execute these steps manually. Maybe you can reanimate your installation.
The rest of your installation seems to be O.K. and not affected by this PHP-FPM error.
Or just try to install it again.
Your error maybe just was caused because of a hanging apt-get of a previous or simultaneous apt-get call.
E: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 15730 (apt-get)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
hcs76
Post by hcs76 »
Same error but in debian 11
install_keyhelp.sh: line 251: php: command not found
PHP version check failed
ERROR: An error occured: unsupported php version
  • minimal install
  • apt-get update
  • apt-get upgrade
  • reboot
  • try installation again
