Install Wordpress [SOLVED]
- MyIDKaTePe
Install Wordpress
i understand that if i want to use wordpress i need to install it manual
but when i want to install i get error on database name
what i already did:
before install i create db and password
i put the info at wordpress form installation
when i submit i get "There has been a critical error on this website."
any idea how to solve this ?
Re: Install Wordpress
More input please!
- MyIDKaTePe
https://i.imgur.com/0806I9F.png
i check on phpmyadmin
no privillage
how to enable privvilage from panel ?
- MyIDKaTePe
You create the db, and then you must be able to use username, database and password within phpmyadmin to connect to the db.MyIDKaTePe wrote: ↑Sat 25. Jun 2022, 17:26 i check on phpmyadmin
no privillage
Unless that works you don't need to try installing WP.
- MyIDKaTePe
No, no need to work with phpmyadmin, that was just meant for testing your db credentials.MyIDKaTePe wrote: ↑Sat 25. Jun 2022, 17:40did you mean ? i must work under phpmyadmin ? no privillage option inside the panel ?
You created the database in the panel, that should be sufficient. But as there seems to be something wrong, phpmyadmin is an easy way to check for error messages.
Here https://imgur.com/zO11JcC you did create the database.
After you click safe you should be able to connect, either via phpmyadmin or the WP installer.
- MyIDKaTePe
Well, WP installer is not quite helpful with the error message, that is why I suggested testing the credentials with PhpMyAdmin.
We need a real error message.
- MyIDKaTePe
Did you try login to PhpMyAdmin?MyIDKaTePe wrote: ↑Sat 25. Jun 2022, 17:59where i can get this real error message ?
- MyIDKaTePe
you were on a database already created. And there is a suggested password.
That is not the current password!
Here: https://imgur.com/l8ISmv1 you try to use the suggested password.
Did you write down the initial password? Use that.
Else: Go again to the db setting, let you suggest a new password, write that down/copy it to the WP installer, save the db dialog.
- MyIDKaTePe
- MyIDKaTePe
Did you write down the initial password? Use that.24unix wrote: ↑Sat 25. Jun 2022, 18:05 OK, in your screenshot https://imgur.com/zO11JcC
that is the password i use
already did
check this: https://i.imgur.com/OgMMWMB.png
https://i.imgur.com/y3MBwsG.png
