keyhelp-toolbox can't run. [SOLVED]
I run keyhelp-toolbox will got error message.
Debian 11
Vmware
22.1.1 (Build 2691)
Fatal error: Uncaught UnexpectedValueException: DirectoryIterator::__construct(/home/keyhelp/www/keyhelp/locale/zh/LC_MESSAGES): failed to open dir: No such a file or directory in /home/keyhelp/www/keyhelp/functions/functions.gettext.php:47
Stack trace:
#0 /home/keyhelp/www/keyhelp/functions/functions.gettext.php(47): DirectoryIterator->__construct()
#1 /home/keyhelp/www/keyhelp/bin/toolbox.php(50): bindAllTextDomains()
#2 {main}
thrown in /home/keyhelp/www/keyhelp/functions/functions.gettext.php on line 47
Expected result
Actual result
Steps to reproduce
Additional information
This directory should /home/keyhelp/www/keyhelp/locale/zh_TW/LC_MESSAGES
Re: keyhelp-toolbox can't run. [SOLVED]
Your system locale is set to zh, KeyHelp expect it to be set to zh_tw (in your case).
The bug in KeyHelp is, the keyhelp-toolbox does not fall back to the default language in this case.
I have fixed it now. You can replace the KeyHelp file with this command and you are good:
cp /home/keyhelp/www/keyhelp/bin/toolbox.php /home/keyhelp/www/keyhelp/bin/toolbox.php ; wget https://install.keyhelp.de/misc/toolbox -O /home/keyhelp/www/keyhelp/bin/toolbox.php ; chown keyhelp:keyhelp /home/keyhelp/www/keyhelp/bin/toolbox.php ; chmod +x /home/keyhelp/www/keyhelp/bin/toolbox.php
Hallo,Alexander wrote: ↑Wed 17. Aug 2022, 10:59 Thanks for reporting!
Ist das script noch up to date?
PHP Fatal error: The file /home/keyhelp/www/keyhelp/bin/toolbox.php encoded as type [1/71] cannot be decoded by this version of the ionCube Loader.
läuft auf der CLI die vom System mitgebrachte PHP Version oder wurde da was verändert?
Das klappt nicht.
Deine Cron-Jobs laufen jetzt wahrscheinlich nicht mehr.
Default CLI muss für Bullseye 7.4 sein.
Wenn Du ein anderes brauchst, dass unter php erreichbar ist, siehe hier: viewtopic.php?t=11705
Danke. Der Link war hilfreich.24unix wrote: ↑Wed 28. Sep 2022, 20:05Das klappt nicht.
