Forbidden error after migration  [SOLVED]
boka003
Post by boka003 »
Ubuntu 20
KVM - Oracle
Last version - 22.2
Additional information
This problem is happening to me with more KeyHelp installations.
The problem is with migration.
I compress all my files at cpanel or plesk server to zip, download zip and upload it to keyhelp via file manager.
After zip extraction, the domain will show a forbidden error.
I was google how to solve this situation and find this thread: viewtopic.php?t=1673
so I was run this command: chown keyhelp:www-data /home/keyhelp
Now my KeyHelp installation showing a forbidden error (not just web site where i extract .zip)
Forbidden
You don't have permission to access this resource.
Is it any way to fix this?
Regards
Re: Forbidden error after migration
boka003 wrote: Mon 28. Nov 2022, 15:16 I was google how to solve this situation and find this thread: viewtopic.php?t=1673
Thank you for this hint.
I removed this answer from the topic.
This answer was misleading and not even part of the topic.
What files / directories do you see inside /home/keyhelp ?
My installation has
/.config
/.lock
/keyhelp.backup
/www
Try
chown keyhelp:keyhelp /home/keyhelp/www
chown root:root /home/keyhelp/www/.well-known
for repairing KeyHelp
Later, after you have fixed your KeyHelp, here are some hints to fix the forbidden for the user account:
1) Check the file privileges here, do they belong to the correct username / usergroup:
/home/users/<USERNAME YOU TRY TO MIGRATE>/www/
2) Also check, if the domain is pointing to the directory you want.
3) Check if in this directory there is an index.html / index.htm /index.php etc. file.
-> So to speak, this is not a bug in KeyHelp and I will move this topic to the appropriate area of this forum.
boka003
Post by boka003 »
Hello Toby,
Thanks for your reply.
This is what I have done now:
root@ch1:~# cd /home/keyhelp
root@ch1:/home/keyhelp# ls
keyhelp.backup  www
root@ch1:/home/keyhelp# chown keyhelp:keyhelp /home/keyhelp/www
root@ch1:/home/keyhelp# chown root:root /home/keyhelp/www/.well-known
root@ch1:/home/keyhelp# cd www
root@ch1:/home/keyhelp/www# ls
adminer            keyhelp              kh.webstats  rainloop   webmail
db-administration  keyhelp.white_label  phpmyadmin   roundcube
KeyHelp still showing same error:
Forbidden
Regards
Please provide the privileges with the command:
ls -la
Of this directories:
/home/keyhelp
/home/keyhelp/www
/home/keyhelp/www/keyhelp
boka003
Post by boka003 »
Alexander wrote: Tue 29. Nov 2022, 09:59 Later, after you have fixed your KeyHelp, here are some hints to fix the forbidden for the user account:
/home/keyhelp/users/<USERNAME YOU TRY TO MIGRATE>/www/
Thank you for your reply.
1) I can not find folder users inside keyhelp:
root@ch1:/home/keyhelp# cd users
-bash: cd: users: No such file or directory
keyhelp.backup  www
But I have found it here:
root@ch1:/home/users/boka003/www#
And here is the output:
root@ch1:/home/users/boka003/www# ls -l /var
total 48
drwxr-xr-x  2 root  root   4096 Nov 29 06:25 backups
drwxr-xr-x 19 root  root   4096 Jan 11  2022 cache
drwxrwxrwt  2 root  root   4096 Aug 12 06:25 crash
drwxr-xr-x 57 root  root   4096 Jan 14  2022 lib
drwxrwsr-x  2 root  staff  4096 Apr 15  2020 local
lrwxrwxrwx  1 root  root      9 Dec  1  2021 lock -> /run/lock
drwxrwxr-x 14 root  syslog 4096 Nov 29 06:24 log
drwxrwsrwx  3 vmail vmail  4096 Jan 14  2022 mail
drwxr-xr-x  2 root  root   4096 Dec  1  2021 opt
lrwxrwxrwx  1 root  root      4 Dec  1  2021 run -> /run
drwxr-xr-x  7 root  root   4096 Dec  1  2021 snap
drwxr-xr-x  6 root  root   4096 Jan 14  2022 spool
drwxrwxrwt  8 root  root   4096 Nov 29 14:09 tmp
drwxr-xr-x  4 root  root   4096 Jan 12  2022 www
2. Domain is in the right directory, if I create file index.html and write test inside, it will show "test" when I visit web site.
3. There was index.php
I had a similar problem when I was trying to migrate WordPress website from Plesk to KeyHelp.
When I created index.html via file manager, it was working fine.
Is there any command that can fix permissions for a single user?
Regards
boka003
Post by boka003 »
Alexander wrote: Tue 29. Nov 2022, 14:11 Please provide the privileges with the command:
ls -la
/home/keyhelp
/home/keyhelp/www
Hello, here is output:
root@ch1:/home/users/boka003/www# cd /home/keyhelp
root@ch1:/home/keyhelp# ls -la
total 32
drwxr-x---  6 keyhelp keyhelp 4096 Oct 28 13:43 .
drwxr-xr-x  6 root    root    4096 Jan 10  2022 ..
drwxr-xr-x  3 keyhelp keyhelp 4096 Apr  8  2022 .config
drwxrwxr-x  2 keyhelp keyhelp 4096 Nov 29 14:25 .lock
-rwxrwxr-x  1 keyhelp keyhelp 1024 Jan 12  2022 .rnd
-rw-r--r--  1 keyhelp keyhelp  165 Oct 28 13:43 .wget-hsts
drwxrwxr-x  5 keyhelp keyhelp 4096 Mar 29  2022 keyhelp.backup
drwxrwxr-x 10 keyhelp keyhelp 4096 Sep  8 02:10 www
root@ch1:/home/keyhelp# cd /home/keyhelp/www
root@ch1:/home/keyhelp/www# ls -la
total 40
drwxrwxr-x 10 keyhelp keyhelp 4096 Sep  8 02:10 .
drwxr-x---  6 keyhelp keyhelp 4096 Oct 28 13:43 ..
drwxrwxr-x  3 root    root    4096 Jan 10  2022 .well-known
drwxrwxr-x  6 keyhelp keyhelp 4096 Jan 14  2022 adminer
lrwxrwxrwx  1 keyhelp keyhelp   10 Jan 14  2022 db-administration -> phpmyadmin
drwxr-xr-x 15 keyhelp keyhelp 4096 Sep  8 02:10 keyhelp
drwxrwxr-x  4 keyhelp keyhelp 4096 Jan 19  2022 keyhelp.white_label
drwxrwxr-x  8 keyhelp keyhelp 4096 Oct 29 00:00 kh.webstats
drwxr-xr-x 12 keyhelp keyhelp 4096 Nov 28 14:26 phpmyadmin
drwxr-xr-x  4 keyhelp keyhelp 4096 Sep  8 02:10 rainloop
drwxr-xr-x 13 keyhelp keyhelp 4096 Sep  8 02:10 roundcube
lrwxrwxrwx  1 keyhelp keyhelp    9 Jan 14  2022 webmail -> roundcube
root@ch1:/home/keyhelp/www# cd /home/keyhelp/www/keyhelp
root@ch1:/home/keyhelp/www/keyhelp# ls -la
total 140
drwxr-xr-x 15 keyhelp keyhelp  4096 Sep  8 02:10 .
drwxrwxr-x 10 keyhelp keyhelp  4096 Sep  8 02:10 ..
-rw-r--r--  1 keyhelp keyhelp  3283 Jun  3 10:08 ajax.php
drwxr-xr-x  2 keyhelp keyhelp  4096 Apr  1  2022 api
drwxr-xr-x  2 keyhelp keyhelp  4096 Apr  7  2022 bin
drwxr-xr-x  3 keyhelp keyhelp  4096 Sep  7 17:07 cache
drwxr-xr-x 44 keyhelp keyhelp  4096 Sep  7 17:07 core
drwxr-xr-x  4 keyhelp keyhelp  4096 Oct 14  2021 cronjob
drwxr-xr-x  2 keyhelp keyhelp  4096 Oct 14  2021 functions
-rw-r--r--  1 keyhelp keyhelp 69267 Aug  5 14:04 index.php
drwxr-xr-x  2 keyhelp keyhelp  4096 Oct 14  2021 init
drwxr-xr-x  5 keyhelp keyhelp  4096 Oct 14  2021 install
-rw-------  1 keyhelp keyhelp   369 Oct 14  2021 license.txt
drwxr-xr-x 20 keyhelp keyhelp  4096 Sep  7 17:07 locale
drwxr-xr-x  6 keyhelp keyhelp  4096 Oct 14  2021 misc
drwxr-xr-x  2 keyhelp keyhelp  4096 Aug 10 15:25 pages
-rw-r--r--  1 keyhelp keyhelp    25 Oct 14  2021 robots.txt
drwxr-xr-x  3 keyhelp keyhelp  4096 Sep  7 17:07 theme
drwxr-xr-x 15 keyhelp keyhelp  4096 Sep  7 17:07 vendor
To fix KeyHelp:
The permissions of the directory /home/keyhelp/ are not correct - do this:
To fix the user:
I had a typo in my path, so yes, "/home/users/..." is correct
You just have to make sure, to have the write file permissions. If they are off, you will encounter unexpected results (wrong diskspace calculation etc.). Always upload files from the context of the user, or perform a chown, if you did it as root, etc.
All files within www/ must belong to the corresponding user.
By the way, you have postet the output of "ls -l /var" instead of the "ls -la /home/users/boka003/www"
boka003
Post by boka003 »
This command fixes my KeyHelp installation.
Here is a screenshot if permissions from the user file manager https://prnt.sc/IETUS4QwPl-j
It is still showing:
Forbidden
root@ch1:~# ls -la /home/users/boka003/www
total 698608
drwxr-x--- 15 boka003 www-data      4096 Nov 30 13:41 .
drwxr-xr-x 10 root    root          4096 Oct 28 13:36 ..
-rw-r--r--  1 boka003 boka003        213 Mar 20  2019 .editorconfig
-rwxr-xr-x  1 boka003 boka003        920 Nov 28 14:56 .env
-rw-r--r--  1 boka003 boka003        739 Mar 20  2019 .env.example
-rw-r--r--  1 boka003 boka003        111 Mar 20  2019 .gitattributes
-rw-r--r--  1 boka003 boka003        151 Mar 20  2019 .gitignore
drwxr-xr-x  3 boka003 boka003       4096 Jul 30  2021 .well-known
-rw-r--r--  1 boka003 boka003       4131 Mar 20  2019 README.md
drwxr-xr-x  2 boka003 boka003       4096 Oct 22  2021 Script
-rw-r--r--  1 boka003 boka003   49748972 Sep 13  2021 Script.zip
drwxr-xr-x 12 boka003 boka003       4096 Sep 13  2021 app
-rw-r--r--  1 boka003 boka003       1686 Mar 20  2019 artisan
-rwxr-xr-x  1 boka003 boka003        899 Sep 13  2021 backup
drwxr-xr-x  2 boka003 boka003       4096 Sep 13  2021 backup-env
-rw-r--r--  1 boka003 boka003  213226884 Oct 28 13:42 backup.zip
drwxr-xr-x  3 boka003 boka003       4096 Sep 13  2021 bootstrap
-rw-r--r--  1 boka003 boka003       1907 Sep  1  2021 composer.json
-rw-r--r--  1 boka003 boka003     249633 Feb 24  2021 composer.lock
drwxr-xr-x  2 boka003 boka003       4096 Jan 22  2022 config
drwxr-xr-x  5 boka003 boka003       4096 Sep 13  2021 database
-rw-r--r--  1 boka003 boka003  452021322 Nov 28 14:54 migracija.zip
-rw-r--r--  1 boka003 boka003        928 Sep  2  2021 package.json
-rw-r--r--  1 boka003 boka003       1156 Mar 20  2019 phpunit.xml
drwxr-x---  8 boka003 boka003       4096 Sep 26  2021 public
drwxr-xr-x  6 boka003 boka003       4096 Feb 24  2021 resources
drwxr-xr-x  2 boka003 boka003       4096 Sep 13  2021 routes
-rw-r--r--  1 boka003 boka003        563 Mar 20  2019 server.php
drwxr-xr-x  5 boka003 boka003       4096 Jul 30  2021 storage
drwxr-xr-x  4 boka003 boka003       4096 Sep 13  2021 tests
drwxr-xr-x 55 boka003 boka003       4096 Sep 13  2021 vendor
-rw-r--r--  1 boka003 boka003       2022 Sep  5  2021 webpack.mix.js
root@ch1:~#
I think that all files have write permissions, as you can see at screenshot above.
Yes, files are uploaded as user via file manager, and then just extracted.
Can you please send me a chown command for fix user problem? I can run command everytime when I upload zip, it is fine to me.
The privileges are fine. But your domain target is very likely not correct.
This looks like a Laravel application - you need to point your domain to the "public/" folder. These kind of applications always "launch" in the public folder. There also should be an index.php.
Additional security advice: Make sure, nobody can access the directory from your screenshot directly. There may be the 'system domain' like boka003.<KEYHELP-DOMAIN> which points to that directory. Nobody should have access to the .env file, which likely contains passwords to the database.
(hmm, maybe i should prevent access to hidden files in general?!)
boka003
Post by boka003 »
Here is image from cpanel file manager: https://prnt.sc/8L5rckodDKE7
Also I have edit link I .env file.
When I open link with /public/ this error show up
Forbidden
You don't have permission to access this resource.Server unable to read htaccess file, denying access to be safe
I had same problem with Wordpress migration.
If privileges are fine, is there anything other that can make problem (even with Wordpress) ?
Regards
Send me the login credentials, i will have a look...
Re: Forbidden error after migration  [SOLVED]
The cause was, the public/ folder was set to privileges "rwx r-x ---" (750) instead of "rwx r-x r-x" (755).
Therfor the web server was not allowed to access this folder and showed a forbidden.
-> After changing the permissions it worked.
