Import Account for KeyHelp
picaditto
Post by picaditto »
Hello to all,
I setup a new server and now i need to import all accounts from the old server.
I double check and dont see any option to do that, any help please.
Notes: The new server dont have the same domain name
Re: Import Account for KeyHelp
Create a backup on the old server and restore these backup on the new server.
picaditto
Post by picaditto »
Jolinar wrote: Tue 14. Jan 2025, 00:37 Create a backup on the old server and restore these backup on the new server.
thanks for the reply.
i have done that, but i think i can´t restore the accounts without first restore the root account, i say these because is the only account that have the option to select.
If i restore the root account, dont mess up with actual root account on the new server?
you can either have a look here - Restore (/Transfer) using the backup system: https://www.keyweb.de/assets/uploads/pd ... ore-en.pdf
Or you can have a look at KeyHelp Pro - where you can transfer single user accounts to a new server: https://www.keyweb.de/en/keyhelp/keyhel ... ement-tool
picaditto
Post by picaditto »
Alexander wrote: Tue 14. Jan 2025, 09:41 Hello,
Hello, thanks for the reply
I have the keyhelp pro, where is the tool to make that? Is in the keyhelp pro admin interface or is there some link to dowload the tool?
blickgerecht
Post by blickgerecht »
Grüße
Roland
technotravel
Post by technotravel »
picaditto wrote: Tue 14. Jan 2025, 14:45
Admittedly not easy to find - it's here: https://k2k.keyweb.de/k2k.conv
Wish you success (plan much time for the migration to finish!)
technotravel wrote: Tue 14. Jan 2025, 16:35
The link can be found from the KeyHelp admin area, within the main navigation on the left below "Help / Links" ;).
(Only on KeyHelp Pro systems)
picaditto
Post by picaditto »
Thanks to all for the support! I will try.
picaditto
Post by picaditto »
One last question, where are the ssh private key for the root account?
technotravel
picaditto wrote: Tue 14. Jan 2025, 20:12 Hello,
Best is you create a new pair of keys for this purpose. Instructions are displayed when you hover over the respective field.
picaditto
Post by picaditto »
Thanks to all.
